link 1km wrap 2c + RB433AH - version 5.0rc3 - more BUGs
All time problem with connection.
rb433 wrap 2c
Mode: AP bridge station
Band: Only-N Only-N
Wirless Protocol: NV2 or any NV2 or any
Data rates: 24,36,48,54 24,36,48,54
Nesterem: off off
Card: R52N R52N
1 R name=“aaa” mtu=1500 mac-address=00:0C:42:62:11:E1 arp=enabled
interface-type=Atheros 11N mode=ap-bridge ssid=“ryb-niwa”
frequency=5060 band=5ghz-onlyn channel-width=20mhz scan-list=default
wireless-protocol=nv2 wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no default-authentication=no default-forwarding=no
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=default compression=no
Freq usage = 0
Ver. 4.x - wrap incemented time x10, before increment worked properly excelent avg=1ms CQQ-100%/100%, past about 30sek ping avg ~500ms, etc
Ver 5.0rc1 - running property about 10~60min, past ping avg 500ms (CQQ - ~25-65%)
Ver 5.0rc3 (NV2) - running property about 10~60min, past ping avg 500ms (CQQ - ~25-65%)
  • don’t properly display signal " " and don’t display CQQ
    Ver 5.0rc3 (not doesn’t mean what i’m set) sometime avg=12ms other time ping avg ~500ms (transfer about 1Mbps, CQQ - ~25-65%, signal -60dBm)
    When I was version 3.30 all was be ok.
    When change to higher version 4.x or 5.x all it’s wrong.
