link 1km wrap 2c + RB433AH - version 5.0rc3
All time problem with connection.
rb433 wrap 2c
Mode: AP bridge station
Band: Only-N Only-N
Wirless Protocol: NV2 or any NV2 or any
Data rates: 24,36,48,54 24,36,48,54
Nesterem: off off
Card: R52N R52N
1 R name=“aaa” mtu=1500 mac-address=00:0C:42:62:11:E1 arp=enabled
interface-type=Atheros 11N mode=ap-bridge ssid=“ryb-niwa”
frequency=5060 band=5ghz-onlyn channel-width=20mhz scan-list=default
wireless-protocol=nv2 wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no default-authentication=no default-forwarding=no
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=default compression=no
Freq usage = 0
Ver. 4.x - wrap incemented time x10, before increment worked properly excelent avg=1ms CQQ-100%/100%, past about 30sek ping avg ~500ms, etc
Ver 5.0rc1 - running property about 10~60min, past ping avg 500ms (CQQ - ~25-65%)
Ver 5.0rc3 (NV2) - running property about 10~60min, past ping avg 500ms (CQQ - ~25-65%)
  • don’t properly display signal " " and don’t display CQQ
    Ver 5.0rc3 (not doesn’t mean what i’m set) sometime avg=12ms other time ping avg ~500ms (transfer about 1Mbps, CQQ - ~25-65%, signal -60dBm)
    When I was version 3.30 all was be ok.
    When change to higher version 4.x or 5.x all it’s wrong.
This problem still time from one year.
Becous support of mikrotk don’t try resolve this problem, don’t recomenned this software.
Did you send your question to support@mikrotik.com ?
Or do you expect that a users forum will solve your issue?
