Link 2 Mikrotik Routers
I am trying to link two Mikrotik Routers so that one of them is connected to internet via a modem and the other is connected to the first Mikrotik router via Ethernet. The first router works fine, I can connect to its Wireless Network and devices connected to the ethernet interfaces can access the internet. The second router however is giving me a lot of trouble. Right now, I can't access the internet even for devices connected directly via ethernet. Here is how my setup looks like right now:
Following are the 2 configs for my devices. I eventually want to Router 1 to be the CapsMan, thats why these settings are already included.
Config Router 1:
add admin-mac=64:D1:54:68:7D:E0 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/interface wireless
managed by CAPsMAN
channel: 2422/20-Ce/gn(20dBm), SSID: MikroTik-687DE5, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce
distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-687DE5
wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=
20/40/80mhz-Ceee distance=indoors frequency=auto mode=ap-bridge ssid=
MikroTik-687DE4 wireless-protocol=802.11
/ip neighbor discovery
set ether1 discover=no
/caps-man configuration
add channel.band=2ghz-b/g/n channel.control-channel-width=20mhz
channel.extension-channel=Ce country=germany datapath.bridge=bridge mode=
ap name=cfg1 security.authentication-types=wpa2-psk security.encryption=
aes-ccm security.passphrase=***** ssid=MikroTik-687DE5
/caps-man interface
add configuration=cfg1 disabled=no l2mtu=1600 mac-address=64:D1:54:62:CC:03
master-interface=none name=cap1 radio-mac=64:D1:54:62:CC:03
add configuration=cfg1 disabled=no l2mtu=1600 mac-address=64:D1:54:68:7D:E5
master-interface=none name=cap2 radio-mac=64:D1:54:68:7D:E5
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys
supplicant-identity=MikroTik wpa2-pre-shared-key=*****
add name=default-dhcp ranges=192.168.88.100-192.168.88.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge comment=livingRoom interface=cap1
/interface wireless cap
set bridge=bridge caps-man-addresses=127.0.0.1 enabled=yes interfaces=wlan1
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=
ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
"enable local wireless interface to be managed by CAPsMAN" dst-port=
5246,5247 protocol=udp src-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="defconf: masquerade"
/ip upnp
set enabled=yes
/system clock
/system identity
set name="MikroTik Main"
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
Config Router 2:
add admin-mac=64:D1:54:62:CB:FF auto-mac=no name=bridgeLocal
/interface wireless
managed by CAPsMAN
set [ find default-name=wlan1 ] ssid=MikroTik
add bridge=bridgeLocal interface=ether2
add bridge=bridgeLocal interface=ether3
add bridge=bridgeLocal interface=ether4
set bridge=bridgeLocal certificate=request discovery-interfaces=ether1
enabled=yes interfaces=wlan1 lock-to-caps-man=yes
add address=192.168.88.2/24 interface=ether1 network=192.168.88.0
add address=192.168.88.3/24 interface=ether2 network=192.168.88.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
/system clock
/system identity
set name="MikroTik LivingRoom"
Please, add to your schema ip addresses of used nets. Looks like you make a mistake with networks assign!
Yours respectfully!
Thank you very much for your reply. I am not 100% what information you require of me. My idea behind the desired IP address setup is the following:
  • Router 1 has the static IP address 192.168.88.1
  • Router 2 has the static IP address 192.168.88.2
  • The device connected to Router 2 via ether 2 has the static IP address 192.168.88.3
All connected devices should be in the 192.168.88.0/24 Network, with the 100-254 range being used for dynamic ips.
I assume, that the 2nd router has nothing to do with routing. It actually works as a switch.
If I see right, your ether1 port is not bridged with the others. You need to switch your config a bit.
  1. Remove all addresses from all physical ports.
  2. Brdige ALL ports (except wlan, as it is managed by CAPsMAN).
  3. Assign new addres 192.168.88.2 to the BRIDGE port (or make DHCP-Client settings for BRIDGE port - not for ether1).
  4. In case of setting DHCP-client for bridge, you will need to set up manually MAC address for bridge as MikroTik likes to change it from time to time when it’s set to default, and your DHCP server may assign different IP in that case.
  5. Make sure that the discovery interface in CAP settings on MikroTik2 is set to your bridge port.
That should be enough.
Awesome, that seemed to work. Thank you so much! You are right, I want the 2nd router to act as a switch.
I took the suggestion of assigning the address 192.168.88.2 to the Bridge and deleting all DHCP-Client settings. Are there any advantages for either approach (i.e. DHCP-Client vs manual assigning)?
Also how would I set a manual ip address for the device connected to ether2 on Mikrotik2? I have deleted all ip addresses as you suggested. Here is my config right now:
Mikrotik 2:
nov/26/2017 00:55:05 by RouterOS 6.38.3
software id = 229J-INAF
/interface wireless
managed by CAPsMAN
channel: 2442/20-Ce/gn(20dBm), SSID: MikroTik-687DE5, CAPsMAN forwarding
add bridge=bridgeLocal interface=ether1
set bridge=bridgeLocal certificate=request discovery-interfaces=bridgeLocal
add address=192.168.88.2 interface=bridgeLocal network=192.168.88.0
/system clock
/system identity
Change your line to:
add address=192.168.88.2**/24** interface=bridgeLocal network=192.168.88.0
Then it should start responding.
What would be the effect of this change? I thought that …/24 is used for matching 0-254 in the last ip block. Here I want one static ip address for Mikrotik2. Using matiaszon instructions everythings seems to be working fine now. All thats left is a static ip for the device connected to ether2.
Well, I like to have all DHCP IP range on MikroTik. All addresses I want to stay the same I just make them static in DHCP lease table. This way you know, they won’t repeat. But if you have not too many devices, and you know, that static IP’s are out of the DHCP pool, there will be no such a big difference.
You can’t set manually on switch/router the IP address of device connected to that switch/router. You have to set it up on THAT DEVICE. And you have to remember that this address has to be unique. I would however strongly recommend to use DHCP isntead. Just let the device to get the address from the router (even if it’s connected to your MikroTik2 it should get the address from MikroTik1). If you want to make sure, that this specific devices will always have the same IP, just log into MikroTik1 and make that lease static. Even if it received a completly different address (for example 192.168.88.249) and you want it to have different (for example 192.168.88.4, the easiest way is to use WinBox, go to IP > DHCP Server > Leases > right-click on that address > Make static > double-click on that line > write an address you want (for example 192.168.88.4) > Apply > OK. You can then renew the address on that device or just simply unplug LAN cable and plug again after while - it should be getting specified address from now on.
It should be:
add address=192.168.88.2/24 interface=bridgeLocal network=192.168.88.0
/24 describes a mask. It’s like using “255.255.255.0” in some other configurations. You have to use it.
