Link bandwidth problem...
This days I have some odd problem with my one location (5GHz links)…
When I use bandwidth test in “receive” mode I have about 25-27Mbps (tcp), same result is in “send” mode…
But when I try “both” mode bandwidth is about 2-3/1-0,5 Mbps then connectivity loss, etc…
Tried different frequencies, with and without nstream but no success…
Any idea what is wrong?
Hi all.
Im having the same behavior. When bandwidth-test between ethernets at more than 3.5Mbit/s everything goes fine, but when bandwidth-test between ethernets at lower values i can not get more than 100kbit/s.
I tried using different equipment, x86, RB411, RB493AH all have the same behavior. Recently i upgrade to ROS4.13. Has anyone experienced this ??
Best regards
