Link Design / Hardware decision
i want to build a Link with Mikrotik Hardware, but i don´t know what is the best for me.
My current planing is:
From Station A to B (15Meter) I want to use 2x 711G-5Hnd with Stationbox Micro (2x2 Mimo 15DB).
I want to connect 711G-5Hnd and RB911G-5HPnD via direct LAN Cable.
Form Station B to C (2000Meter) I want to use 2x RB911G-5HPnD with Stationbox XL (2x2 Mimo 19DB).
At the Moment i have bought 2x RB911G-5HPnD with Stationbox XL.
What do you think is the best Hadrware for my setup, do you think the hardware planing is ok or should i use rb433 with 2x miniPCI Radios on Point B ?
I want to bring my 100mbit cable internet from Point A to C.
Can’t you do A-B by cable?
Also: Can’t you do A-C in 1 link (line-of-sight) ?
15 dB is way too much for A-B. You need to lower the output power for it to work.
19 dB is probably OK for the 2KM link, but I would take antennas with a smaller beamwidth.
If you cant do cable from A to B by any means, get 2x SXT Lite5. Lower the power output to like 5dBm.
You want to keep the received signal in 50-60 range.
As mentioned before, for the 2km link you will be OK if you are aiming for 100mbit throughput.
I can´t go by cable and there are some trees between a and C.
Do you think SXT Lite5 are ok, because there have no gigabit ethernet.
The money is not the problem, we need only a good link.
Thanks for your Answer.
Greetings from Germany.
You mentioned 100mbit as the target for the link, thats why I suggested Lite5.
If you need more, go with SXTG 5HnD.
if there is tree in between, can you post it…
