Link Disconnection
Hello Guys,
I submitted a link of 40 km ultilizzando 29 Duplex and radio antennas Jirous Ubiquiti SR71-15a-N wireless protocol streme 5600 and frequency of the link goes to the great I -60dB/-60dB signals with 100% CCQ therefore apparently a great link except that the same multiple times a day I go down to 3/10 sec and then back up again, apart from interference in your opinion what could be causing these sudden disconnections?? a friend suggested I change the radio Ubiquiti Mikrotik with those as well, I do not know more sensitive, I ask you some advice.
thanks
maybe your antennas are very closer of other antennas in the tower. you can use noise-inmunity on advance menu and put on ap y client mode for try, other sugestion is set the scan list to only one frecuency on cpe mode. this help you to a fast reconnection link.
you can do an analisis spectral too, open a new comand windows and write “interface wireless spectral-history range=(here the range to scan ex:5100-5200 number 0, enter)”, this can help to see the channel saturation.
Have you checked the connections, is there ingress of water, also to rule out interference on 5600 test with another frequency,
Nice shot -60/-60 40km :slight_smile: Jirous are making good antennas
Have 28km link Jirous 29Db R52Hn radio -64/-65 130-140 (TCP tested with 5 simultaneous connections) mbit with nv2
with nstreme I get about 100-110 mbit but unstable (like in ur case 20-30 disconnects a day) or data rate will drop
if u use nstreme just enable nv2 see if link disconnect
