RB7xx with v5.8.
Is it possible that RB doesn’t DHCPREQUEST the address immediately after link down+link up?
There is DHCP authorisation on the network and if the provider equipment reboots it clears DHCP access table, and if there is no DHCP entry then no access. Nearly everything re-requests dhcp after link up so I hope it’s caused by something else. I cannot check since it’s not a local router.
