Link Down - Only recourse is to reboot (6.40.3 on x86)
Hi All,
I have a hotspot server with a campus wide bridge servicing several buildings. Each building has a switch plugged to their own port on the hotspot controller.
Recently I have had an issue where an entire building will go down. Only rebooting the controller will re-enable the bridge port.
I thought it was an STP issue at first but don’t see any info in the logs.
Enabling/disabling the port does not work - only rebooting the entire controller.
I’m on 6.40.3 and have replaced the hardware - still there.
Has any new features/bugs - this setup has run fine since 2014.
Thanks!
