Link interfaces don't work.
I’m using Links between 2 RouterOSs to monitore the traffic, but with some routers there is problem that The Dude can’t find any interfaces and also makes no traffic. If I use WinBox clicking on the device it work’s, but finding and displaying the intefraces don’t work.
I don’t know which protocol use The Dude for this monitoring, but it doesn’t work. Thanx for your advices :slight_smile:
Are you positive it’s RouterOS? Do links appear under SNMP?
-Brad
