I have a new CRS-310 running SwOS 2.18 and have a issue with getting a link from a single specific device on my network.
It’s Gato Audio Network stream that links up perfectly with 3 other switches that I have tried with. On the CRS-310 I get no link, no matter if I run auto or try a specific speed setting for the port.
I can get it to work by adding a swich in between the device and the CRS-310 so I know cables etc. are working ok.
No error messages on the switch or anything, any way to troubleshoot on the CRS-310?
i’ve 3 CRS310, but only on routeros, never use and try swos.
I’ve see this fix in 7.20.1 :
*) routerboard - fixed non-running interfaces for CRS310-8G+2S+IN after booting to SwOS ("/system routerboard upgrade" required) (introduced in v7.20);
Thanks, not the issue here as interface works with other devices, just not my network streamer.
Have you try forced speed/duplex
Yes, all combinations has been tried.
Juste on one interface OR all ?
Have you change the cable category ? and brand ? I already have some mistake on cisco switches with bad connector
