Hi All, first time poster and new Dude user. When I discover a network the map draws all the devices, but does not draw the links or dependencies. It’s probably something simple I’m overlooking, thanks in advance for any replies.
Update: I’ve checked in the “Links” folder and there are no links listed. So I guess my question now is, why are the devices discovered, but not the links?
Another update: I’ve discovered a remote network with the Dude, this one does render the links (and shows them in the folder). But no links are discovered on the local network. Very confused…
I don’t use auto discovery so the only suggestion I have is to verify SNMP is working, “hover” on the device and you should see uptime as well as other SNMP data.
Thanks for the karma!
