Link Long Range
I’m having a problem with a link to 42Km.
32.5 dBi Antenna Hyperlink DualPol cards SR71-A, RB433AH.
Signal -56.
When I put traffic passing through the RB’s, the link goes down.
If I do the bandwidth test, I get full 20MB. But the link goes down after a few minutes.
Here are the settings of the 2 sides.
SIDE A
[admin@GBLX_MEGA_CLU] > int wireless pr advanced
0 R name=“wlan1” mtu=1500 mac-address=00:15:6D:84:15:DE arp=enabled disable-running-check=no
interface-type=Atheros 11N radio-name=“00156D8415DE” mode=ap-bridge ssid=“GBLX_CLU_A0” area=“”
frequency-mode=manual-txpower country=brazil antenna-gain=0 frequency=5500 band=5ghz-onlyn
scan-list=default rate-set=configured supported-rates-b=“” supported-rates-a/g=“”
basic-rates-b=“” basic-rates-a/g=“” max-station-count=2007 ack-timeout=dynamic
tx-power-mode=default periodic-calibration=disabled periodic-calibration-interval=60
dfs-mode=none wds-mode=disabled wds-default-bridge=none wds-default-cost=100
wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=no default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=long compression=no
allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0
ht-guard-interval=long ht-extension-channel=disabled ht-supported-mcs=mcs-3,mcs-11
ht-basic-mcs=mcs-3,mcs-11 ht-txchains=0,2 ht-rxchains=0,2 ht-amsdu-limit=8192
ht-amsdu-threshold=8192 hw-retries=4 frame-lifetime=0 adaptive-noise-immunity=none
hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0
SIDE B
[admin@GBLX_MEGA_OLV] > int wireless pr adv
0 R name=“wlan1” mtu=1500 mac-address=00:15:6D:84:15:2B arp=enabled disable-running-check=no interface-type=Atheros 11N radio-name=“00156D84152B”
mode=station ssid=“GBLX_CLU_A0” area=“” frequency-mode=manual-txpower country=brazil antenna-gain=0 frequency=5500 band=5ghz-onlyn scan-list=default
rate-set=configured supported-rates-b=“” supported-rates-a/g=“” basic-rates-b=“” basic-rates-a/g=“” max-station-count=2007 ack-timeout=dynamic
tx-power-mode=default periodic-calibration=disabled periodic-calibration-interval=60 dfs-mode=none wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=long compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00
ht-ampdu-priorities=0 ht-guard-interval=long ht-extension-channel=below-control
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-9,mcs-11 ht-txchains=0,2 ht-rxchains=0,2 ht-amsdu-limit=8192 ht-amsdu-threshold=8192
hw-retries=4 frame-lifetime=0 adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0
I tried several different configurations, but can not establish the connection.
Does anyone have an idea?
's
Breno
PS:
In a new test, I realized that using UDP packets the connection does not fall, if use tcp with 20 simultaneous connections the link falls. But if I use 1 tcp the link does not fall … and now?
Version 4.5.
Use static ACK settings and enable Nstream.
I’ll second that. Nstreme is the only way to get a solid link for that distance.
shouldn’t he put the value 32.5 dBi in the antenna-gain (It is 0 in his configuration) ??
No
OP, are you me? I also have a 26 mile link I’m trying to get working with 802.11n.
Definitely nstream
Definitely don’t both filling out the antenna gain and such
Turn on adaptive noise immunity for “ap & client mode” on both sides
antenna gain value is only used to calculate the eirp output of the antenna for your country in case you set “Frequency Mode” to “regulatory domain”.
If not is has no meaning in ROS
“nstream”: has issues with 802.11n still not solved. Also has issues with small packages (voip) on furthermore idle links in any a/b/g/n setup. Only use it when your links are always transporting sufficient amounts of traffic.
“antenna gain and such”: see my post before this one. If you have reg. domain set it might well be the radio power is set to a low value just to stay within limits of your country.
“adaptive noise immunity”: To be set “ap & client mode” on the ap-bridge/bridge radio and “client mode” on the station radio.
Early versions of 4.xROS couldn’t handle the “adaptive noise immunity” on ´n´ protocol at all. I am not sure if they entirely do in the last ROS.
I found it makes a difference on the ´station´ running radio but not on the AP
Well, u guys make me feel more confident at least. I have a 1.5 mile link in NY im going to be setting up next week that im worried about, sure makes me feel better when u guys are complaining about issues going 26 miles! lol!!!
–John
