Hello community, I have a Mantbox AX 15S as a sector antenna and an LHG5 AX antenna as a CPE. I want to set up a link to get service. I don't know if anyone here has already done this configuration. I had the same equipment with an older version, but I don't know if anyone has done it with these newer models. Any help or information would be great, thanks.
Loosely, you want the Mantbox set up as AP and the LHG5 as station or station-bridge, this depends if what you are trying to setup is a routed connection or a L2 "wireless wire" one.
The default configuration of the LHG should be already be fine for the routed CPE :
If you want a L2 transparent bridge you need to put all interfaces into the bridge and change mode from station to station-bridge.
and the Mantbox should have the default WISP bridge, fine for both cases:
The Mantbox will have a DHCP client on bridge, so you might need to add manually a static IP of 192.168.88.2/24 to the bridge, while the LHG should already have the static 192.168.88.1/24 set.
