Link more than max turns to white color
I’ve noticed that at least in version 6.43.4, if a link is set to speed (for example) gigabit and snmp gets a current bandwidth value more than 1Gbps then the link turns white.
Is this a bug or is it intended?
If it is intended, would it be possible to be able to set that color and not have white color on links?
I know that the correct thing would be to set the max speed more than 1Gbps but there could be cases where one wants to have the link appear as full even if it has a fraction of the max throughput.
