Hi all frends iam in iraq i have a isp and i use a mikrotik system, now i want expanded the wire less coverage i have a 2 mikrotik link using as a point to point, but i cannot configuratin u can give me a good configuration with print screens picture.
try this page from manual:
http://www.mikrotik.com/testdocs/ros/2.9/interface/wireless.php
also there are various examples in wiki, think which one suits your needs best:
http://wiki.mikrotik.com/wiki/Wireless_Setups
hi janisk ok i set up and used this gonfiguration if yuo look this link http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks
but iam affraid not worked in more distance approx 8km and i have aproblem with bandwidth this configuration transfered only 2 Mbps, if you have abetter configuration for this perpus (link between tow points) please advice me.
again thank you for your help.
Aree O.Wasat M.
Sulemany
Iraq
00964(0)7701981983
Areearee,
What configuration did you end up using? Also can you describe your link in more details? I also recommend just routing your entire wireless setup for maximum bandwidth.
Matt
What do you mean by “just routing”? Disabling WDS and just adding “Routes” in the route list?
You got it! If you use EoIP or WDS it just adds packet overhead and can cause your like to be alot slower then needed. By removing all the possible tunnels, it will also mean less things to go wrong.
Matt
Sure thing
I just wonder if that compromises PPPoE which I use for my costumers.
Lollo,
I use this setup on mine and i also have pppoe customers. No problems.
Matt
