Dear people,
I need your help to solve my problem with XR3 card.
I install XR2 on a couple of Mikrotik RB433AH in wds mode and they work fine. After that I swapped them with the XR3-3.5 Frequency Range. I have the following config:
[1st rb433AH]
mode:ap_bridge
band: 5GHz-5MHz (I know there is a 2GHz down conversion)
fx:5765 Mhz
[2nd rb433AH]
mode:wds station
band: 5GHz-5MHz
fx:5765 Mhz
All other settings are default.
Sometime they link but they are very unstable (link lost every 5 minute). If I change any other fx there is no way to link them.
If I change the band to 5GHz-10Mhz I cannot link them at all.
The strange matter is that if I look at ‘status’ pan in the wds station I can see the frequency scan but they never link even if the frequency match. Besides the frequency scan is not in a linear way but it seem completely random. I made a freq scan and I can only see a very low freq usage (less than 0.7%) only in 5765,5770,5775 channel.
My MT level is 5 and version is 4.11.
Can you help me?
Gatman
