Link problem with Cisco
I need help, i have one routerboard 230 with .version 2.8.9 connected through PoE port to a Cisco 1721. They seem to have problems with negotiation, if i check link on the Mikrotiks Ethernet interface it shows "link Ok", but when i try to ping router Cisco, it shows "ping timeout". It was necesary for the "link OK" to appear to disable autonegotiation on the mikrotik interface. But the ping problem still remains. They dont communicate.
What should i do??
Thanks.,
Martin Castillo
Make sure the addressing is correct. Netmask is important.
Can you ping other devices from the MT on that port? Can you ping other devices from the Cisco on the port that goes to the MT?
Depending on what ports you are using, you may need a crossover cable instead of a straight through cable. Some equipment does not seem to like auto-sense ports on the other end. Also, I would turn off auto-negotiate on both devices and set the speed and duplex as you want it. I have seen Cisco equipment take up to 1-1/2 minutes to negotiate and then in a couple of seconds restart the negotiation.
Also, you do not say how far apart the devices are, so I assume they are close. There is a minimum cable length in the IEEE spec, but I do not remember what it is. Cthe long-cable setting on the MT. I believe MT told me to turn it on if the cable is over 90 meters.
Thanks,
The problem turned out to be the Power Over Ethernet Adapter, once a i changed it, link went up. The funny thing is that this damaged POE adpater let me comunicate with my PC to the Mikrotik, but didn’t let comunicate Cisco with MT router.
Regards,
Martín Castillo.
some (don’t remember which exactly) Cisco routers/cards had problems with autonegotiation function
