I have SFP S+RJ10 in a CSS326-24G-2S+ switch.
I am probably missing something but is there any way to get the link status of the SFP ports?
In the “link” tab of SwOS, it always show “link on 10G” whatever there is a cable pluged into the SPF or not.
In the “SFP” tab, it only shows the modules vendor, part number, revision, serial, date and type without any other information.
There is no “SFP Status” tab at all.
Also, how is it possible to set the link speed? If I disable “auto-negotiation”, I can only choose between 1G, 100M and 10M. With “auto-negotiation”, it shows 10G whatever there is something connected to it or not. But those modules are supposed to also support 5Gbps and 2.5Gbps.
I tried S+RJ10 transceiver with Mellanox ConnectX-2 card on Linux as well as non-Mikrotik switch and both systems always report link as 10Gbe, even if the link drops down to 1Gbe, so I think this is just the way it is with SFP+ modules. I haven’t been able to test NBase-T yet.
I’m hearing from network engineer folks I know that this is typical of copper SFP transceivers across vendors. That boggles my mind, as I have no idea how LAGs could be effective in a wire loss scenario if link is always on.
Just an FYI, about an hour ago I installed a S-RJ01 into a CSS326-24G-2S that has SwitchOS 2.8. It behaved exactly as I expected. Link showed as down with no cable plugged in. When I plugged in a cable to a RB260GS with a third party SFP, the link came right up and showed 1G. Pings to both the far end switch and another device plugged into that switch came right up.
As I said, exactly as it should have.
