I’ve installed Dude (3.6) and its working fine, except that my master router (CCR 1016-12G) even though I’m using routeros and locked onto the port on the CCR, instead of showing its locked at 1GB, shows 3 bps capacity!
So the links red even though there’s up to 220 MBytes/sec when the interface is flat out.
Its not just one, ether 2, 3, 4, 5, 6 show up as 3 byte capacity and according to dude all overloaded.
Only ether 1 and 7 show 1Gbps capacity.
Okay ether 1 runs no a non MT point., but reads correctly on dude. Ether 2 and 3 run in and out of a Dell Poweredge and both the CCR and Dell say the interfaces at 1Gbps.
Ether 4 and 5 run into a pair of CRS 125-24G-1S-RM. The interface on the CRS and CCR shows 1Gbps, but dude says 3 bps.
Ether 6 runs to a 8 port un-managed GB switch, also confirmed 1 gbps but dude 3 bps.
Now ether 7 runs to a MT951G but dude says 1Gbps!
Ive even reversed the link using the CRS end, its the same anything with exception of 1 and 7 that come from CCR the link speeds not being detected.
Should I try 4.0b3?
