Linksys wap11 compatibility
Hi, does anyone knows if linksys WAP11 work as a client of a mikrotik AP 2.4ghz?.
Because I can see de AP but can´t get traffic between them.
due to lynksys setting there equipment to only connect to lynksys no it will not work but if you flash the equipment with openwrt or ddwrt or such it will if you can find a flash for the model you are working with
