Hello guys
Is there anyone here using ubuntu 11.04 im just wondering why the all.npk files doesnt drag to winbox/file im a little bit confuse.
Hello guys
drag&drop is not working on wine.
i use ftp or scp to move npk files to the router.
i have bash script that fetches files, then connects to router, gets arch, and then uploads files required by the arch. So IMHO, it is even easier to use
than drag and drop available on the M$windows.
thanks for the tips SCP is really good!!
I am using Fedora 15 with wine 1.3.24 and drag&drop works here.
I remember that early on Fedora 14 was not working.
ubuntu still uses wine 1.2.2
just upgraded to 1.3.27 and Yes drag&drop works
yes, just tried with 1.3.25 it drag and drop from Dolphin in KDE works like a charm
on debian up@date with wine from repo it works well
try open file window in winbox and drag files there, not into void space
I don’t know about winbox, but the webfig UI can upload the files, or you can scp or sftp them to the router from a Linux box. I’ve used both sftp and uploading via webfig to upgrade.
it works now sir mrz i upgrade the latest version now i can drag and drop…
