linux wine netinstall and compact flash - howto?
Is it possible to use netinstall to install an x86 version of routeros onto a compact flash?
I’ve no problems running winbox with wine and ubuntu but when I run netinstall there are no drive mappings for the compact flash card (via a USB card reader).
Do I need to partition, format and mount the CF card prior to the netinstall ?
thanks for any help - I really don’t want to have to setup a windows box just for this purpose!
thanks,
Derek
Netinstall is not working with wine.
Bummer. Does anyone know if its possible to get the CF USB reader to operate with netinstall in VMWARE (linux host, windows XP guest)?
thanks
D
for vmware you can try to access your CF adapter directly and map that device to vm-guest, but i am not sure if that will work as you and me expect it.
safe bet would be to run netinstall in your guest or using gksudo in native linux and run installation over netowrk - as it is know, that this is working correctly and without any problems.
Bullshit, I’ve just installed 3.30 via netinstall from wine.
i tryed netinstall using wine (In archlinux), 9/2012 and it shows som bind bootp failed…error…
Try running Netinstall as superuser.
I’ve turned off firewall, but the Netinstall.exe will receive “REQ RECEIVED: bind tftp general failed: (10048)” and will crash. How to get it to bind into tftp or what it is trying to do?
Also, I see a lot of similar messages under Wine when the device is Ethernet booting:
recv bytes: 300
opcode: 1
htype: 1
hlen: 6
hops: 0
xid: 1e81c
secs: 2304
unused: 0
ciaddr: 0.0.0.0
yiaddr: 0.0.0.0
siaddr: 0.0.0.0
giaddr: 0.0.0.0
chaddr: 0:c:42:e:67:4d:
sname:  (64)
file:  (128)
cookie: 63538263
  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  3c  09  4d  69  6b  72  6f  62  6f  6f  74  ff  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  0vend:
REQ RECEIVED:
FAILED TO REPLY
and
TFTP timeout
recv bytes: 300
opcode: 1
htype: 1
hlen: 6
hops: 0
xid: 1bf90
secs: 4352
unused: 0
ciaddr: 0.0.0.0
yiaddr: 0.0.0.0
siaddr: 0.0.0.0
giaddr: 0.0.0.0
sname:  (64)
file:  (128)
cookie: 63538263
0  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  3c  09  4d  69  6b  72  6f  62  6f  6f  74  ff  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  vend:
REQ RECEIVED:
ENTERING TFTP LOOP
