LIST ALL QUEUES AND APPLY A FIREWALL.
Hello.
I’m trying do a script then i can get all the ip’s of the client’s and aply a firewall, the clients make part of a parent, this parent also have a ip, but this ip doesn’t have apply a firewall.
How can i get all the ip of the cliente.
I know how to the a ip of a specific cliente:
:global a [/queue simple get User target-addresses]
:put $a
[/ip firewall filter add chain=forward src-address=$a action=accept]
This script take the ip of a queue and put in the screen and apply a firewall
I need urgently a scrip that do this with all queues.
:foreach i in=[/queue simple find] do={
/ip firewall filter add chain=forward src-address=[/queue simple get $i target-address] action=accept
Ohhh guy thanks.
That’s good.
Now i have more three doubts.
First: How can i list only the queues that have a parent?
Second: I need run this scrip all five minutes during all. (Scheduller)
Third: When i run the scrip some times, the script do any same ip firewall rules, i need that if the script already is created, don’t do the rule.
Thanks for the help.
  1. add check - if parent!=“none” then do your script
  2. add scheduler with interval=5m
  3. add another check - run through all firewall filters, search for specific src-address. If rule with that address is already added then do nothing, otherwise add.
Ohh Thanks.
How can i put in the script that if parent!=“none” do { ?
Hummm, can you help me put ine my script this?
This is my script until now:
/queue simple
:foreach n in=[/queue simple find priority=8] do={
:local interfacename [/queue simple get [$n] target-addresses]
:local c [/queue simple get [$n] name]
:local parent [/queue simple get [$n] parent]
/ip firewall filter add chain=foward src-address=“$interfacename” action=accept comment=“$c”
Thanks guy.
:foreach n in=[/queue simple find priority=8 parent!="none" ] do={
  :local newIP;
  :local ipaddress [:tostr [/queue simple get $n target-addresses]];
  :for i from=( [:len $ipaddress] - 1) to=0 do={
     :if ( [:pick $ipaddress $i] = "/") do={
        :put  [:pick $ipaddress 0 $i];
        :set newIP [:pick $ipaddress 0 $i];
  :local c [/queue simple get $n name];
  :put $c;
  :if ([:len [/ip firewall filter find comment=$c]] = 0) do={
     /ip firewall filter add chain=foward src-address=$newIP action=accept comment=$c;
  } else={
     :put "already added";
Ohhhh really thanks guy.
But the script doesn’t do the rules, any idea?
And how can i do the scheduller.
Have u msn, e-mail?
Where u from guy?
Thanks.
ok added lines to remove netmask, this should work.
what if you have a queue named ‘none’? =) maybe you should forbid such name…
Hummm.
The script isn’t add the rules.
Do you know why?
:local ipaddress [:tostr [/queue simple get $n target-addresses]]; → What do the comand “tostr”?
What do you do here?
:if ( [:pick $ipaddress $i] = “/”) do={
My mikrotik is the version v3.20, this really will ok?
Really thanks guy.
Works for me on v3.24
tostr converts ip address to string (not necessary in this case but script will work anyway)
Queu taget-address contains netmask (for example “1.1.1.1/32”), but src-address in firewall is not allowing to add ip addresses with netmasks at the end. So that is waht I am doing - removing netmaks.
Hummm.
Thanks now i understood.
Look until where did:
:foreach n in=[/queue simple find priority=8 parent!=“none”] do={
:local interfacename [/queue simple get $n target-addresses];
:put $c;
/ip firewall filter add chain=foward src-address=$interfacename action=accept comment=$c;
Now i would like post a log, example if the script run , post a log “Scritp “name” sucessfully” or not.
How ever?
Thanks.
at the end of the script add following line:
:log info “type your log message”
Well it is hard to make everything foolproof. Just don’t use “none” as queue name.
Hi guys.
Now i have more problems ehehehe, :laughing: .
Let’s look my script until now:
:local ipnumber [/queue simple get $n target-addresses];
:local comentario [/queue simple get $n name];
:put $comentario;
:if ([:len [/ip firewall filter find comment=$comentario]] = 0) do={
/ip firewall filter add chain=foward src-address=$ipnumber action=accept comment=$comentario;
:log info “A regra de firewall do queue $comentario com ip $ipnumber foi adicionada com sucesso.”;
This script do some things that i want, bu no all that i need.
Now, i i’m into a very hard problem:
When i go to delete/rename a queue, the rule of firewall created by the script, don’t be removed and don’t remoned, like this:
I go delete a queue, when i deleted this queue, i need that the script verify all the queues, and if exists a firewall rule, that the comment isn’t equal of the queue name, the script remove the queue, that do the same thing if a queue is renamed, the script remove the old rule, and after with a scheduler the script create the new queue with new name.
