List for interface type
Is there a way to add all eoip interfaces to a bridge without specifying each interface name? That is, is there a way to add an interfaces to a bridge by type?
I have multiple eoip interfaces, and would like to add them to a bridge and add them to an interface list.
This is what I have now:
/interface eoip
add allow-fast-path=no mac-address=02:81:zz:zz:zz:zz name=eoip-tunnel-to-212 remote-address=\
    xxxxx.sn.mynetname.net tunnel-id=355
add allow-fast-path=no mac-address=02:46:dd:dd:dd:dd name=eoip-tunnel-to-371 remote-address=\
    ggggggggg.sn.mynetname.net tunnel-id=37135
add interface=eoip-tunnel-to-371 list=DHCPdisabled
add interface=eoip-tunnel-to-212 list=DHCPdisabled
add bridge=bridge interface=eoip-tunnel-to-212 unknown-unicast-flood=no
add bridge=bridge interface=eoip-tunnel-to-371
/interface bridge filter
add action=drop chain=forward comment="DHCP Drop " dst-port=67-68 in-interface-list=DHCPdisabled ip-protocol=udp log=yes mac-protocol=ip
But, before going to each MT device and adding all eoip interfaces, I was hope there is a way to make the configs more portable.
This is what I would like:
/interface eoip
add <ALL-EOIP-INTERFACES> [or ALL-INTERFACES-IN-'EOIP-IFACE-LIST'] list=DHCPdisabled
add bridge=bridge [ALL-EOIP-INTERFACES] or [ALL-INTERFACES-IN-'EOIP-IFACE-LIST'] or [interface-list=DHCPdisabled]
Thank you.
You can add a whole interface list as a bridge member port rather than a single individual interface; if you do that, the interface list is a static member port of the bridge (so shown by export) and the member interfaces of the list are added as dynamic member ports (so only shown by print). You can try someting like this:
/interface/list/add name=all-eoip
/interface/bridge/port/add bridge=bridge interface=all-eoip
:foreach i in=[/interface/eoip/find] do={/interface/list/member/add list=all-eoip interface=$i}
From this point on, you still have to add each new eoip interface to the list manually, or make the oneliner more complex so that it would update the list rather than expect it to be empty.
If it does not work the way above (the second row fails), just swap the order of execution of the 2nd and 3rd one.
Wow, that is powerful.
I’m still struggling with the DHCP ROGUE server detected, so I need to put this on the back burner for now.
You are, as always, a generous fountain of help.
