List of setup Needs for RBLHGR&R11e-LTE6
As I need help with this, I thought I would form it in a form that new people could read with straight forward answers.
Needs:
1- RBLHGR&R11e-LTE6
2- Mounting equipment (pole… etc)
3- Cat6 outdoor cable to run from the RBLHGR&R11e-LTE6 to inside the home. ( looking for opinions on length)
4- Cat 6 cable to run to the router. (again, length suggestions would be great)
5- an outlet on the inside of home to power the PoE. (suggestions on the cleanest look.. maybe photos.)
6- Router.
7- laptop to configure the modem (prior to connecting to router). Then to set up router.
Guys am I forgetting anything. Also, looking for any suggestions on this and what I might be missing. I will edit the list as needed.
you are sure to lghr and you know what band-s you interested?
Hi SiB.
I thought that the cat6 model handle all N America bands. Is that not accurate? Was hoping to test the unit with all major carriers as I have signed my leasing contracts with them.
Always not trust anyone. Just check documentation/information and do testing.
I know about r11e-lte-us who have FDD Bands: 2 (1900MHz) / 4 (1700MHz) / 5 (850MHz) / 12 (700MHz)
but the r11e-lte6 have :
FDD : 1 (2100MHz) / 2 (1900MHz) / 3 (1800MHz) / 7 (2600MHz) / 8 (900 MHz) / 20 (800MHz) / 5 (850MHz) / 12 (700MHz) / 17 (700MHz) / 25 (1900MHz) / 26 (850MHz)
TDD: 38 (2600MHz) / 40 (2300MHz) / 39 (1900MHz) / 41n (2500MHz)
You see that LTE6 not have B4 1700Mhz but have got B2/5/12.
Other problem is you should check what realy Band’s are in your region because maybe you can have other Band’s what MikroTik not have but you should have.
Aks ISP - check google and wikipedia.
