i was looking how to remove bridge and have deafult config working as in RB750 ... there is everything like here but without bridge ...
i'll try to do this
but here is what you asked
(p.s. i'm config this connected to my pc ruter (thats why rb450h has 192.168.1.xx ip address cose i want my courent connection to the net working while i configure this router)
/interface export
jan/02/1970 00:33:58 by RouterOS 4.14
software id =
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes comment="" disabled=no forward-delay=15s l2mtu=1524
max-message-age=20s mtu=1500 name=bridge priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1524
mac-address=00:0C:42:A4:A3:B6 master-port=none mtu=1500 name=ether1-gateway speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1524
mac-address=00:0C:42:A4:A3:B7 master-port=none mtu=1500 name=ether2-local speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1524
mac-address=00:0C:42:A4:A3:B8 master-port=none mtu=1500 name=ether3-local speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1524
mac-address=00:0C:42:A4:A3:B9 master-port=none mtu=1500 name=ether4-local speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1524
mac-address=00:0C:42:A4:A3:BA master-port=none mtu=1500 name=ether5-local speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1 switch-all-ports=yes
add bridge=bridge comment="" disabled=no edge=auto external-fdb=auto horizon=none interface=ether3-local path-cost=10
point-to-point=auto priority=0x80
add bridge=bridge comment="" disabled=no edge=auto external-fdb=auto horizon=none interface=ether4-local path-cost=10
add bridge=bridge comment="" disabled=no edge=auto external-fdb=auto horizon=none interface=ether5-local path-cost=10
add bridge=bridge comment="" disabled=no edge=auto external-fdb=auto horizon=none interface=ether2-local path-cost=10
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set (unknown) vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=
disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60
mac-address=FE:3E:5D:64:2B:84 max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=
1460 mrru=disabled
/ip address print detail
0 ;;; default configuration
address=192.168.88.1/24 network=192.168.88.0 broadcast=192.168.88.255 interface=ether2-local actual-interface=bridge
1 D address=192.168.1.214/24 network=192.168.1.0 broadcast=192.168.1.255 interface=ether1-gateway
/ip route print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
0 ADS dst-address=0.0.0.0/0 gateway=192.168.1.1 gateway-status=192.168.1.1 reachable ether1-gateway distance=1 scope=30
target-scope=10
1 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.214 gateway=ether1-gateway gateway-status=ether1-gateway reachable
distance=0 scope=10
2 ADC dst-address=192.168.88.0/24 pref-src=192.168.88.1 gateway=bridge gateway-status=bridge reachable distance=0 scope=10
/ip firewall export
jan/02/1970 00:37:05 by RouterOS 4.14
software id = JG40-WX4B
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s
tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="default configuration" disabled=no protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established disabled=no in-interface=
ether1-gateway
add action=accept chain=input comment="default configuration" connection-state=related disabled=no in-interface=
ether1-gateway
add action=drop chain=input comment="default configuration" disabled=no in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" disabled=no out-interface=ether1-gateway
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
TNX
