Queue Simple Rate Setting Tool
This Tool can be helpful for ISP's to change a big number of queues simple
Written by:BrasDeutscher,PA,Brazil
Testet under RouterOS v6.37rc32
Enter here the max-limit search value
Required is k or M , do not use m
:global oldmax "0/0"
Enter here the limit-at search value
:global oldat "0/0"
Set the new max-limit value here
:global newmax "0/0"
Set the new limit-at value here
Required is k or M do not use m
:global newat "0/0"
!!-- If you use burst queue's you can set the new burst values below --!!
!!-- If not leafe all next rules as it is by my script default set --!!
If required set the new burst limit here
:global bl "0/0"
If required set the new burst-threshold here
:global bt "0/0"
If required set the new burst-time here
:global but "0s/0s"
If required set the new priority here
:global py "8/8"
You have the option to set comments here, if no leafe it as is "my comment"
:global cm ""
!!-- DO NOT CHANGE ANY BELOW --!!
:global ip
:global action
:foreach q in=[/queue simple find ] do={
:set ip [/queue simple get $q target ];
:if ([/queue simple find where ! disabled ! dynamic target="$ip" limit-at="$oldat"
max-limit="$oldmax" ] != "" ) do={
:delay 100ms;
:set action [/queue simple set [find where target="$ip" limit-at="$oldat" max-limit="$oldmax" ] limit-at="$newat"
max-limit="$newmax" burst-limit="$bl" burst-threshold="$bt"
burst-time="$but" priority="$py" comment="$cm" ];
:log warning ("O.K $ip set new Value limit-at=$newat max-limit=$newmax burst-limit=$bl");
:log warning ("O.K $ip set new Value burst-threshold=$bt burst-time=$but burst-limit=$bl comment=$cm");
} else={
:log error ("error $ip max-limit=$oldmax limit-at=$oldat not found");
