I am having an issue with a Mikrotik router, where I cannot pass LLDP across a bridge. To test the functionality I setup two ports on an RB750 with software 6.x (all versions seem affected in 6), plug a cisco 2960 into both sides, then test LLDP across the bridge, it doesn’t pass. I can see everything else, nothing else that I can tell is being blocked. If I plug the cisco devices into each other LLDP passes fine. If I do this same test with the 5.x software it works fine. It works fine if I use master and slave ports, but for this circumstance my ultimate goal is to bridge an EOIP tunnel and a port, that needs to pass LLDP for this customer. Anyone seent his?
Did any one find a solution tp this topic ?
