I'm trying to get LLDP working on my devices.
I have one CCR2004-1G-12S+2XS as core router and, on sfp-sfplus9, one RB2011UiAS-2HnD connected on sfp1.
Both routers are using VLANs (ethernet interfaces > bridge > vlan).
CCR2004 acts as capsman for the RB2011.
Both routers are able to ping each other
MNDP works pretty well, both routers can see each other
RB2011 sees CCR2004 via LLDP, but CCR2004 do not see RB2011 via LLDP
I've seen this layer 2 misconfiguration, but it doesn't apply to my use case (both routers' interfaces are configured with protocol-mode=none already.
Both router are configured the same way:
set discover-interval=5s lldp-mac-phy-config=yes lldp-vlan-info=yes protocol=lldp,mndp
i have other devices on the same network and LLDP is working without any issue.
I'm a bit stuck with this issue. Any help or advice will be appreciated.
