Edit : please read this summary and conclusion thread before :
https://forum.mikrotik.com/viewtopic.php?t=203774
All the stuff below are the details that led to the final conclusions. PVID = 1 or not is not the culprit for LLDP-MED not working.
Setup : RB5009, RouterOS 7.14beta7
I have some hybrid ports in a bridge for phones.
On those hybrid ports i have a tagged VLAN for telephony, and an untagged guest VLAN to allow to connect some devices on the secondary phone PC ports.
I’m using LLDP MED to switch the phone to the right Voice VLAN. This is necessary to avoid the hassle of configuring the phone. Using LLDP MED, the phone setup is fully automatic through auto-provisionning at boot time directly on the voice VLAN.
The problem is that if i want to use something else than VLAN ID = 1 for the guest VLAN, LLDP MED does not work anymore.
It seems that LLDP announcements are working only if the untagged VLAN has ID = 1
On switches it is possible to use any VLAN ID for the untagged guest VLAN and LLDP MED still works.
Could someone confirm this problem ?
