lmt lte18 CAPsMAN setup
Hello
I have lmt lte18 CAPsMAN and cap ax, and I want to create a network using CAPsMAN.
I have some previous experience working with basic routers setting up capsman but with lmt lte18 I just can’t do it. |
Do you have any tips for beginner?
You need wifiwave2 package on controller for capsman with cap ax.
Beware for consequences on lte18 ( can’t check all details now using phone).
Edit
I see ipq 4019 on that screenshot.
Sure it’s cap ax and not cap xl ac ? That’s something completely different !
yea, its cap xl ac
my bad
Which device acts as controller ?
Is capsman enabled there ?
Lmt lte18 is ax device ?
Then I am afraid it is not possible since it needs legacy wifi package for legacy cap devices.
You should have taken cap ax.
