LNS on CHR (Performance Questing)
With RouterOS, I’m planning multiple CHR setups to serve as LAC/LNS.
We have a lot of subscribers and active traffic.
I plan to divide the subscribers into CHR as access replicator and use CCR2216-1G-12XS-2XQ as Router.
Please suggest me a 10G or 40G or 100G side, CHR NIC that you can recommend directly, fully compatible with MikroTik and experienced.
Also, if there are tricks on the VM Esxi side, give them all.
I want to set up LNS with MikroTİK CHR and I serve 10000+ active subscribers.
we can brainstorm
I’m curious about your ideas and comments.
This may help to gauge hardware, resources and throughput although it doesn’t specifically relate to LNS/LAC
MikroTik CHR – Breaking the 100G barrier
https://stubarea51.net/2021/12/13/mikrotik-chr-breaking-the-100g-barrier/
