Load Balancd Policy
Dear All…
Any one have an idea to implement Load balance on this configuration
I have two VSAT ISPs first with 4Mbps and second with 2Mbps
I need a configuration lets me configure the router to do load balance also to direct the service automatically to one of the ISPs if the other fails…
If u r asking what services I’m using in the router, simply only the routing nothing else because i have network environment all my clients are connected to my primary core switch and have the IPs from DHCP server and so on I intend to put the mikrotik router between the VSATs and the Cisco core switch.
I found something in wiki but its talking about two groups, i only have one group here and it seems thats there is no complex deal in what i need…
so please i need your idea and advice in this.
Regards
Mimoave
http://www.mikrotik.com/docs/ros/2.9/ip/route
Regards
