I have done load balancing with pfSense but just got my first RouterBoard today.
I can not find a single guide that does not use static IPs.
All my WANs are DHCP and the IP/Gateway can be in very different pools and change frequently.
Is it possible to load balance with DHCP WANs?
Edit:
I found a script that apparently will help me setup load balance on DHCP WANs.
:local clientcounter
:local routecounter
:local duplicatecounter
:local routeupdated "no"
:foreach clientcounter in=[/ip dhcp-client find] do={
:local routingmarkname ([/ip dhcp-client get $clientcounter interface] . "-mark")
:local newroutinggateway [ip dhcp-client get $clientcounter gateway]
:foreach routecounter in=[/ip route find where routing-mark=$routingmarkname] do={
:local routinggateway [/ip route get [find routing-mark=$routingmarkname] gateway]
:if ([:len $newroutinggateway] > 0) do={
:if ($"routinggateway" != $"newroutinggateway") do={
/ip route set $routecounter gateway=$newroutinggateway
:set routeupdated "yes"
:if ($routeupdated = "no") do={
/ip route add routing-mark=$routingmarkname gateway=$newroutinggateway dst-address=0.0.0.0/0
Can someone confirm it will work for my setup?
MikroTik RouterOS 5.14 (c) 1999-2012 http://www.mikrotik.com/
jan/02/1970 01:00:13 dhcp,critical,error dhcp-client on ether2 lost IP address 154.20.241.99 - received NAK from dhcp server 192.168.1.254
[admin@MikroTik] > /export compact
# jan/02/1970 01:13:11 by RouterOS 5.14
# software id = ULUJ-IPE8
add admin-mac=00:0C:42:F3:6F:FB auto-mac=no l2mtu=1598 name=bridge-local protocol-mode=rstp
set 0 name=ether1-gateway
set 5 name=ether6-master-local
set 6 master-port=ether6-master-local name=ether7-slave-local
set 7 master-port=ether6-master-local name=ether8-slave-local
set 8 master-port=ether6-master-local name=ether9-slave-local
set 9 master-port=ether6-master-local name=ether10-slave-local
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6-master-local
add address=192.168.88.1/24 comment="default configuration" interface=bridge-local
/ip dhcp-client
add comment="default configuration" disabled=no interface=ether1-gateway
add disabled=no interface=ether2
add address=192.168.88.0/24 comment="default configuration" dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
/ip firewall mangle
add chain=prerouting dst-address=192.168.1.0/24 in-interface=bridge-local
add chain=prerouting dst-address=154.20.240.0/24 in-interface=bridge-local
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ether1-gateway new-connection-mark=wan1
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ether2 new-connection-mark=wan2
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=bridge-local new-connection-mark=wan1 \
per-connection-classifier=dst-address:2/0
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=bridge-local new-connection-mark=wan2 \
per-connection-classifier=dst-address:2/1
add action=mark-routing chain=prerouting connection-mark=wan1 in-interface=bridge-local new-routing-mark=towan1
add action=mark-routing chain=prerouting connection-mark=wan2 in-interface=bridge-local new-routing-mark=towan2
add action=mark-routing chain=output connection-mark=wan1 new-routing-mark=towan1
add action=mark-routing chain=output connection-mark=wan2 new-routing-mark=towan2
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
add action=masquerade chain=srcnat out-interface=ether2
add distance=1 gateway=192.168.1.1 routing-mark=towan1
add distance=1 gateway=154.20.240.254 routing-mark=towan2
add distance=2 gateway=154.20.240.254
/tool mac-server
add disabled=no interface=ether3
add disabled=no interface=ether4
add disabled=no interface=ether5
add disabled=no interface=ether6-master-local
add disabled=no interface=ether7-slave-local
add disabled=no interface=ether8-slave-local
add disabled=no interface=ether9-slave-local
add disabled=no interface=bridge-local
/tool mac-server mac-winbox
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
add interface=ether6-master-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=bridge-local
[admin@MikroTik] >
