load balance doesn't work on v6.7, help!
I can’t find what’s wrong with my config, only WAN1 shows active in /ip route
/ip firewall mangle
#   manually force local traffic to connected networks to stay in the main routing table
add action=accept chain=prerouting disabled=no dst-address=192.168.201.0/24
add action=accept chain=prerouting disabled=no dst-address=192.168.202.0/24
add action=accept chain=prerouting disabled=no dst-address=192.168.203.0/24
#  rules that will sort the traffic into streams.
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no dst-address-type=!local \
in-interface=ether5 new-connection-mark=WAN1 passthrough=yes per-connection-classifier=both-addresses:3/0
in-interface=ether5 new-connection-mark=WAN2 passthrough=yes per-connection-classifier=both-addresses:3/1
in-interface=ether5 new-connection-mark=WAN3 passthrough=yes per-connection-classifier=both-addresses:3/2
#  mangles to add the routing marks to the packets based on the connection mark in the PREROUTING CHAIN
add action=mark-routing chain=prerouting connection-mark=WAN1 disabled=no in-interface=ether5 \
new-routing-mark=ether1-mark passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2 disabled=no in-interface=ether5 \
new-routing-mark=ether2-mark passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN3 disabled=no in-interface=ether5 \
new-routing-mark=ether3-mark passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1 disabled=no new-routing-mark=ether1-mark passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2 disabled=no new-routing-mark=ether2-mark passthrough=yes
add action=mark-routing chain=output connection-mark=WAN3 disabled=no new-routing-mark=ether3-mark passthrough=yes
#  Identify which WAN interface the traffic came in and mark the connections appropriately.
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no \
    in-interface=ether1 new-connection-mark=WAN1 passthrough=yes
    in-interface=ether2 new-connection-mark=WAN2 passthrough=yes
    in-interface=ether3 new-connection-mark=WAN3 passthrough=yes
/ ip route
#  Create the unmarked default routes.
add dst-address=0.0.0.0/0 gateway=192.168.201.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.202.1 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.203.1 distance=3 check-gateway=ping
#  Create the marked default routes
add dst-address=0.0.0.0/0 gateway=192.168.201.1 routing-mark=ether1-mark check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.202.1 routing-mark=ether2-mark check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.203.1 routing-mark=ether3-mark check-gateway=ping
/ ip route
Only one of this can be active, the one with lower distance.
What you get is the normality.
Only one DEFAULT route with 0.0.0.0/0 can be active.
You can not balance the DEFAULT (no-mark) traffic.
The DEFAULT traffic can go out only from one route.
Rextended, thank you for prompt reply. Actually, today test showed me somewhat balanced traffic, though WAN1 busier then the other two.
By any chance would you happen to know how can I split my lan to two networks 192.168.10.0/24 and 192.168.20.0/24 with 20%/80% of total wan1-3 capacity
Y
Read the slide of mum on venice 2014 mum.mikrotik.com :wink:
Probably because was late at night, but I can’t find it :frowning:
Looked in here: http://wiki.mikrotik.com/wiki/MUM_2014_IT
