Have a router with the following route table entry:
3 ADo dst-address=0.0.0.0/0 pref-src=xx.yy.zz.50
gateway=xx.yy.zz.65,xx.yy.zz.93 interface=1-dsl,2-dsl
gateway-state=reachable,reachable distance=110 scope=255
target-scope=10 route-tag=0
However, the router is sending ALL traffic out only the 1-dsl interface.
(and there are currently 1678 connections, so at least a few of them should have picked the alternative path when they were established).
Here is a snapshot statistic, note outbound traffic is only using 1-dsl.
1-dsl
received-packets-per-second: 150
receive-drops-per-second: 0
received-bits-per-second: 1202.2kbps
sent-packets-per-second: 368
transmit-drops-per-second: 0
sent-bits-per-second: 868.0kbps
2-dsl
received-packets-per-second: 300
received-bits-per-second: 2.3Mbps
sent-packets-per-second: 0
sent-bits-per-second: 0bps
This worked fine in 2.9. After rebooting, the situation is the same, except its now routing ALL traffic via 2-dsl, and ignoring 1-dsl. Also, it if matters or not, the route table actually contains many entries (in addition to the default gateway) that all specify 1-dsl,2-dsl as their path.
