Hi
I did all the load balance settings for two ppoe WAN 12mb each and I got it to work, but the problem it works when I download with torrent my download speed is 2.4mbs but when i use IDM it only uses one WAN i tried different IDM but none will work.
here are my settings if someone can check them out and tell me if i did something wrong or i need any additional settings.
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark \
in-interface=WAN1 new-connection-mark=WAN1_conn
in-interface=WAN2 new-connection-mark=WAN2_conn
dst-address-type=!local in-interface=LAN new-connection-mark=WAN1_conn \
per-connection-classifier=both-addresses:2/0
dst-address-type=!local in-interface=LAN new-connection-mark=WAN2_conn \
per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
in-interface=LAN new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
in-interface=LAN new-routing-mark=to_WAN2
add action=mark-routing chain=output connection-mark=WAN1_conn \
add action=mark-routing chain=output connection-mark=WAN2_conn \
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add check-gateway=ping distance=1 gateway=WAN1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=WAN2 routing-mark=to_WAN2
add check-gateway=ping distance=2 gateway=WAN1
thank you
