load balance pcc and (1 isp service provider or multi isp )
hi
i want to loadbalance 3 dsl line 4 mb each one pppoe bridge
some friend told me you have to bring the service (from same isp provider to avoid isp delay and success pcc marge)
some friend told me no problem bring the service (from different isp provider and mikrotik will do the job)
so can some one here tell me some thing from personal experience
thanks
I’m not sure what you’re asking for. Are you asking how to do it or are you asking have any of us done it successfully? Yes, I have done it successfully. No, it does not work the way I would have thought it was going to work before I tried it. I highly recommend you play with PCC and understand it before you implement it because it may not be the right solution for you. You can use Oracle Virtual Box and create multiple routers to test this out with. You can do that for free before you commit yourself to it and then you will know, with confidence, if that is the right solution for you.
