Load Balance Problem
please suggest me abou the following
i have 20 nos of 1mbps internet connection and want to loadbalance them and use them on 2 pc to get faster browsing and downloading speed.
following is a rough network config ( | denotes a single lan cable)
cn1 cn2 cn3 … cn20
Switch
Mikrotik router
switch
pc1 pc2
i neet to load balance them so as to get download speed of ~~ 20 mbps
how to do that?
please
help
Load balancing doesn’t work that way. You don’t get 20mb with 20 x 1mb connections you get your connections distributed across those 20 1mb connections. If you’re doing something that creates a lot of connections like torrents then you’ll see a benefit but for streaming media or downloads it will still only be a 1mb connection
i will try to access few site at once first one should go through wan1 second one through wan2 and so on
how to do that
