Load balance w/ sites
Hi
sorry 4 my poor english
but i need help !!!
i have this :
10.10.0.1 Gateway1 | 10.10.1.1 Gateway 2
Mk NAT (Load Balance)
192.168.8.0/24 (clients)
But i need use Gateway 2 for download only youtube videos
how to make it???
tks 4 any help
´s
Hello Thunder ,
yes you can do that using the following mangle and route rules
at /ip firewall mangle
3 chain=prerouting action=mark-routing new-routing-mark=youtube
passthrough=yes src-address=0.0.0.0/0 dst-address=208.65.152.0/21
4 chain=prerouting action=mark-routing new-routing-mark=youtube
passthrough=yes src-address=0.0.0.0/0 dst-address=72.14.192.0/18
5 chain=prerouting action=mark-routing new-routing-mark=youtube
passthrough=yes src-address=0.0.0.0/0 dst-address=74.125.0.0/16
at /ip route
add comment=“” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.10.1.1
routing-mark=youtube scope=255 target-scope=10
I have to include also google videos still coz they r linked from youtube ,I ll do that later at night
regards,
hi.. i’m working in load balance depending on the destination ip but i can’t make it work :frowning:
i tried the example above but no luck. i use dst-addresslist instead dst-address because a have in address list, a list with the ip of sites i want to redirect to the alternative wan.
i’ve been reading all wiki examples and i arrived to a solution similar to the one posted above but no luck
my router has no mangle rules, because i use a traffic shapper in another pc… this router is only used for nat & firewall.
i have:
2 lan interfaces bridged
2 wan interfaces (wan1 ip 200.45.??.??/255.255.255.248 :: wan2 ip 10.0.0.2/255.255.255.0)
i want to route youtube through wan2
a squid pc conected to lan1
all clients connected to lan2
lan network=172.16.0.0/21
in ip/firewall/nat i don’t use masquerade. i use scr-nat and dst-nat (i assign some public ip to clients)
i use a nat rule to redirect all packets to port 80 to the squid pc
i don’t pretend you to give me the exact code, i just would like some guide, some general steps to follow… i’m lost
thanks in advance & sorry for my poor english
i solve it. i was making a mistake marking packet from the squid
