Hi All,
I have tried to setup load balancing from the wiki, but it does not seem to want to work with my setup.
We have two adsl lines,
adsl line 1 ip address 192.168.1.254
adsl line 2 ip address 10.0.0.138
Both are from the same ISP each ADSL line has modem set to masquerade
ADSL1 ADSL2
192.168.1.254 10.0.0.138
ETH2 192.168.1.222 ETH3 10.0.0.1
ROUTER1
ETH1 192.168.xx.xxx MIKROTIK ROUTER NEEDS LOAD BALANCE SETUP
ETH1
ROUTER2
If anyone could help with the load balancing on this (with or without failover) it would be greatly appreciated.
ashish
October 3, 2007, 4:01am
2
Please Post your configuration here, coz it works fine for me.
ASHISH
/IP ADDRESS
0 192.168.200.10/24 192.168.200.0 192.168.200.255 local
1 10.0.0.1/8 10.0.0.0 10.0.0.255 ADSL-TOP
2 192.168.1.222/24 192.168.1.0 192.168.1.255 ADSL-BOTTOM
3 D 192.168.201.10/32 192.168.201.9 0.0.0.0
/IP FIREWALL
0 chain=srcnat action=masquerade
Ethernet Adapters:
Local
ADSL-TOP
ADSL-BOTTOM
I have removed the setup, for load balancing as we were unable to use the internet at all when the load balance rules were in place.
But the wiki setup was exactly the same as the setup that I used here, the only diffirence is interface and ip address in the lines were changed to match our setup, and I disabled the nat rule that we already had.
NAT RULE disabled =
This is how I changed the wiki setup to suite my setup
/ip firewall mangle
add chain=prerouting in-interface=ADSL-TOP connection-state=new nth=1,1,0
action=mark-connection new-connection-mark=odd passthrough=yes comment=“” disabled=no
add chain=prerouting in-interface=ADSL-TOP connection-mark=odd action=mark-routing
new-routing-mark=odd passthrough=no comment=“” disabled=no
add chain=prerouting in-interface=ADSL-BOTTOM connection-state=new nth=1,1,1
action=mark-connection new-connecton-mark=even passthrough=yes comment=“” disabled=no
add chain=prerouting in-interface=ADSL-BOTTOM connection-mark=even action=mark-routing
new-routing-mark=even passthrough=no comment=“” disabled=no
add chain=srcnat connection-mark=odd action=src-nat to-address=192.168.1.222
to-ports=0-65535 comment=“” disabled=no
add chain=srcnat connection-mark=even action=src-nat to-address=10.0.0.1
add dst-address=0.0.0.0/0 gateway=192.168.1.254 scope=255 target-scope=10 routing-mark=odd
add dst-address=0.0.0.0/0 gateway=10.0.0.138 scope=255 target-scope=10 routing-mark=even
add dst-address=0.0.0.0/0 gateway=10.0.0.138 scope=255 target-scope=10 comment=“” disabled=no
foffa
October 3, 2007, 10:10pm
5
to ashish
i have load balancing running
but when tracing any address using tracert
only 1 router is pinging and the other router appear as * and time out in the tracert
like this
1 1 ms <1 ms <1 ms 10.0.0.2
2 * request time out<<<
<< this must be the external (router 2) it was 192.10.10.1
from another client working with the other (router 1)
2 1 ms <1 ms <1 ms 192.168.1.1
now why this happenn
note load palancing working fine with hotspot
i tested this with hotspot and without hotspot
anothr thing maybe some one help me in
i want to make portforward
foffa
October 3, 2007, 10:33pm
6
for your problem
(passthrough=yes)
this is the error you make
how ever i think all right
you have to make passthrough=no
in winbox you will find this in the managle rule remove it from every managl rule it is a mark
To ashish
Any info on my setup,
Really need to get it working as our sat link went down, and 1 ADSL line is not enough for the clients.
