Hi every one
Can any one help me out how to load balance 2Wans in mikrotik 450g
Hi every one
Hi
There are 3 Load Balance method:
ECMP
Nth
PCC
I think for 2 (or more) internet wan link PCC is best choice.
It’s explained in http://wiki.mikrotik.com/wiki/PCC
pcc would be your best bet…try looking for mikrotik pcc examples… google is your friend. you can have a look at https://www.google.co.za/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&cad=rja&uact=8&ved=0CHcQFjAG&url=http%3A%2F%2Faacable.wordpress.com%2F2011%2F07%2F27%2Fmikrotik-dual-wan-load-balancing-using-pcc-method-complete-script-by-zaib%2F&ei=-0gzU5fYPKqu7AaK-YDwAw&usg=AFQjCNEuFSYEFucGmeI0qB848QZ8vAWbUA&sig2=wxohw3JPd5gO9YrjuIViKw&bvm=bv.63738703,d.ZGU he has a good system and i use parts of it.
Thank you for your post friends
But in my router this concept is not working.
Kindly help me out for load balancing in mikrotik 450g
PCC can sometimes be difficult to control and sometimes breaks secure https sites.
I recommend creating two lan or subnets and assign them their own gateway wan.
http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways
