Load Balancer PCC and package marking in same MK
I have a balancer following the example of Mikrotik Wiki ..
/ ip address
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=bridgeFTTH
add address=10.111.0.2/24 network=10.111.0.0 broadcast=10.111.0.255 interface=ISP1
add address=10.112.0.2/24 network=10.112.0.0 broadcast=10.112.0.255 interface=ISP2
/ ip firewall mangle
add chain=prerouting dst-address=10.111.0.0/24  action=accept in-interface=bridgeFTTH
add chain=prerouting dst-address=10.112.0.0/24  action=accept in-interface=bridgeFTTH
add chain=prerouting in-interface=ISP1 connection-mark=no-mark action=mark-connection \
    new-connection-mark=ISP1_conn
add chain=prerouting in-interface=ISP2 connection-mark=no-mark action=mark-connection \
    new-connection-mark=ISP2_conn
add chain=prerouting  in-interface=LAN connection-mark=no-mark dst-address-type=!local \
    per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=ISP1_conn
    per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=ISP2_conn
add chain=prerouting connection-mark=ISP1_conn in-interface=bridgeFTTHH action=mark-routing \
    new-routing-mark=to_ISP1
add chain=prerouting connection-mark=ISP2_conn in-interface=bridgeFTTH action=mark-routing \
    new-routing-mark=to_ISP2
add chain=output connection-mark=ISP1_conn action=mark-routing new-routing-mark=to_ISP1
add chain=output connection-mark=ISP2_conn action=mark-routing new-routing-mark=to_ISP2
/ ip route
add dst-address=0.0.0.0/0 gateway=10.111.0.1 routing-mark=to_ISP1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 routing-mark=to_ISP2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.111.0.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 distance=2 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=ISP1 action=masquerade
add chain=srcnat out-interface=ISP2 action=masquerade
But in the same way, I will place package marking, my question is, in which part of the balancer code do I have to place the marking of packages and connections, according to the example of the balancer code that I have?
For example I have the following …
add action=mark-connection chain=prerouting comment=\
    "/////////////////////MARCADO DE PAQUETES//////////////////////" \
    new-connection-mark=icmp_conn passthrough=yes protocol=icmp
add action=mark-packet chain=prerouting comment=ICMP connection-mark=\
    icmp_conn new-packet-mark=icmp_pack passthrough=no
add action=mark-connection chain=prerouting comment="DNS - conexiones" \
    new-connection-mark=dns_conn passthrough=yes port=53 protocol=udp
add action=mark-packet chain=prerouting connection-mark=dns_conn \
    new-packet-mark=dns_pack passthrough=no
    "HTTP - Paginas puerto 80" new-connection-mark=http_conn passthrough=yes \
    port=80 protocol=tcp src-address-list=UCA_FTTH
add action=mark-packet chain=prerouting connection-mark=http_conn \
    new-packet-mark=http_pack passthrough=no
    "HTTPS - conexiones puerto seguro 443" new-connection-mark=https_conn \
    passthrough=yes port=443 protocol=tcp src-address-list=UCA_FTTH
add action=mark-packet chain=prerouting connection-mark=https_conn \
    new-packet-mark=https_pack passthrough=no
add action=mark-connection chain=prerouting comment="CORREO MAIL" \
    new-connection-mark=mail_conn passthrough=yes port=25,110,143,465,587,995 \
add action=mark-packet chain=prerouting connection-mark=mail_conn \
    new-packet-mark=mail_pack passthrough=no
add action=mark-connection chain=prerouting comment="Youtube - conexiones" \
    content=youtube dst-port=80,443 new-connection-mark=conexion_youtube \
    passthrough=yes protocol=tcp
add action=mark-connection chain=prerouting content=youtube dst-port=80,443 \
    new-connection-mark=conexion_youtube passthrough=yes protocol=udp
add action=mark-connection chain=prerouting content=googlevideo dst-port=\
    80,443 new-connection-mark=conexion_youtube passthrough=yes protocol=tcp
    80,443 new-connection-mark=conexion_youtube passthrough=yes protocol=udp
add action=mark-connection chain=prerouting content=youtu.be dst-port=80,443 \
add action=mark-packet chain=prerouting connection-mark=conexion_youtube \
    new-packet-mark=paquetes_youtube passthrough=no
add action=mark-connection chain=forward comment="Speed Test Server" \
    layer7-protocol=SpeedTest new-connection-mark=SpeedTest_Con passthrough=\
    yes
add action=mark-connection chain=prerouting new-connection-mark=SpeedTest_Con \
    passthrough=yes protocol=tcp src-port=8080
add action=mark-packet chain=prerouting connection-mark=SpeedTest_Con \
    new-packet-mark=SpeedTest_Packets passthrough=no
add action=mark-connection chain=postrouting dst-port=8080 \
    new-connection-mark=SpeedTest_Con passthrough=yes protocol=tcp
add action=mark-packet chain=postrouting connection-mark=SpeedTest_Con \
add action=mark-packet chain=prerouting comment="Windows Update list dst" \
    layer7-protocol=MicrosoftUpdates new-packet-mark=winupdate-mark \
    passthrough=no
Thanks for you support !!
Each packet can have only one connection mark, so when you need more than one for different purposes, it doesn’t have straightforward solution. You can probably create combinations like ISP1_http_conn, ISP2_http_conn, but working with that won’t be pleasant at all, all the extra rules, etc.
On the other hand, connection marks for load balancing are needed for incoming connections, to route replies back the same way, so you can have those as special kinds next to others. You just need to fix old ones to not re-mark them, so either mark only unmarked connections (connection-mark=no-mark), or mark only new ones (connection-state=new), look only at specific direction (in-interface=LAN), etc. It should be doable.
