load balancer
the load balancer of wiki don´t work i need some another load balancer for 4 wan
thanks
why doesn’t it work?
It is working for me also..
andycrazy -
Posting the wiki loadbalancer doesn’t work is not very helpful in determining what can be done to help you out… You need to be a little more specific.
Posting your config would help a lot to determine where you went wrong. Also your goal with using a loadbalancer, such as failover required yes/no, or are you balancing certain kinds of traffic http out one gateway while VoIP goes out another, etc…
hey at least not for me or i guess so, all load balance with fail over i ever seen in this post treat equal, 1 2 3 or more conections with statics and privates ip’s on wan sides but… i have 2 adsl modems trhowing public and dynamics ips to my nics card on my mikrotik so..
how can i do load balance with fail over with this scenario???
regards!!!
