Does anybody have a working script with two WAN Interfaces (loadbalanced) and more than 1 LAN Interface (best 4 LAN different Networks).
Would like to use it.
script to do what? It hink you mean setup. or config. Try to do a search in here. It’s like 30% of all answer here. is about more than one wan connections. And how to setup. depends on your connections. and setup, plan and goal.
as the headline is saying a script for Load Balancing 2 WAN with 4 LAN ports
