I have 3 T-1 lines. Each with a class /27 (30 IPs) on each.
I have a gateway address for each of the T-1s.
All 90 IPs can be routed down any of the 3 T-1 lines.
All gateways have different IP addresses. In my case all three gateways have the same MAC address as well.
All three T-1 lines go through cisco 2600 routers, then go to a cisco switch, then to the MT router.
The MT has two interface cards, one for the internal LAN and one for the Internet IP space. On the Internet side the NIC card has three public IPs that point to the three T-1 lines. Internal NIC (LAN) has a single IP address.
Works well - all servers that are NAT’d (both source and destination) seem to have no difficulty getting to the Internet, users have no problems getting to the servers from the Internet…
Masq or src NAT’d only - this is where this setup runs into trouble. I have source Masq’d (past) and now src NAT’s about 50 stations behind the MT and have src NAT’d them to a 10 IP block range, i.e. xxx.xxx.xxx.10 - xxx.xxx.xxx.20.
This will work as long as the loading on the three T-1 lines is relatively low (30% or less), at higher say 40% capacity, the src NAT’d only stations seem to hang, or take a VERY long time to load web pages…
I can go to any of the fully NAT’d stations and this does not happen - though intermittantly I will get a momentary ‘hang’, very momentary as in a second or two, and only at T-1 loading above 75% (I have to make the lines push ths much data using a bandwidth tester) and then it won’t ‘hang’ again - this I expect is from the DNS taking a moment to get the request in and out before actually going to the IP address because of the loading of all T-1 lines…
CPU is a 2.4Ghz, 512MB memory, 40GB HD.
I see CPU loading of the MT at max of 25%, normally the MT ‘rides’ at about 3% with peaks from 6-8% from time to time.
I have run external mtr (Linux Multi Trace Route) program and get less than 1% packet loss at ANY load ratio on the T-1s, and on the three addresses on the MT router Internet NIC.
So - any of you smart folks out there have any ideas 'cause I am fresh out…
Thom
