Hello
I want to merge two channels between the head office and the branch office so that the channels work simultaneously.
If one of the Internet channels disappears, the connection works through the second channel in auto switching.
(The branch in the Internet goes through the head office)
At the head office there is 1 Internet 100 Mbps /fiber channel
In the office of branch 2 of the Internet channel 50 Mbit /fiber channel (2 ISP)
I set up 2 EoIP channels in the head office and branch office.
Took them into bond. (balance-rr)
When two internet connections are available, the two internet channels are well loaded.
if I disable any link in the branch office, packet loss begins.
router branch writes:
12:23:11 interface,info ether2-WAN2 link down
12:23:21 interface,info eoip-tunnel2 link down
12:23:22 interface,warning eoip-tunnel2 transmit loop detected, downing interface for 60 seconds
12:24:20 interface,info eoip-tunnel2 link up
12:24:31 interface,info eoip-tunnel2 link down
12:24:32 interface,warning eoip-tunnel2 transmit loop detected, downing interface for 60 seconds
In this case, the eoip-tunnel2 in the head office does not down.
Tell me i’m setting it right Load balancing and failover ?
head office
WAN IP 5.5.5.5
second WAN IP 5.5.5.6
LAN 192.168.100.0/24
model = CCR1009-
RouterOS 6.43.12
add fast-forward=no name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] name=ether1-Wan-I1 speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] name=ether5-LAN speed=100Mbps
set [ find default-name=ether6 ] speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
set [ find default-name=sfp-sfpplus1 ] advertise=10M-full,100M-full,1000M-full
/interface eoip
add loop-protect=off mac-address=02:20:98:72:C9:A2 name=eoip-tunnel1 remote-address=11.11.11.10 tunnel-id=500
add loop-protect=off mac-address=02:20:98:72:C9:A2 name=eoip-tunnel2 remote-address=22.22.22.10 tunnel-id=501
/interface bonding
add mii-interval=50ms name=bonding1 slaves=eoip-tunnel1,eoip-tunnel2
add bridge=bridge1 interface=ether5-LAN
add bridge=bridge1 interface=bonding1
add address=192.168.100.14/24 interface=ether5-LAN network=192.168.100.0
add address=5.5.5.5/27 interface=ether1-Wan-I1 network=5.5.5.0
add address=5.5.5.6/27 interface=ether1-Wan-I1 network=5.5.5.0
add address=172.16.10.29/30 interface=eoip-tunnel1 network=172.16.10.28
add address=172.16.10.33/30 interface=eoip-tunnel2 network=172.16.10.32
add address=172.16.10.41/30 interface=bonding1 network=172.16.10.40
add distance=1 gateway=192.168.100.10
add distance=1 dst-address=11.11.11.10/32 gateway=5.5.5.1
add distance=1 dst-address=22.22.22.10/32 gateway=5.5.5.1
add distance=1 dst-address=192.168.91.0/24 gateway=172.16.10.42
branch office
model = 2011UiAS
RouterOS 6.43.12
WAN1 11.11.11.10
WAN2 22.22.22.10
LAN 192.168.91.0/24
add bridge=bridge1 interface=ether6-TestP
/interface eoip
add loop-protect=off mac-address=02:26:13:F5:00:56 name=eoip-tunnel1 remote-address=5.5.5.5 tunnel-id=500
add loop-protect=off mac-address=02:26:13:F5:00:56 name=eoip-tunnel2 remote-address=5.5.5.6 tunnel-id=501
/interface bonding
add address=11.11.11.10/30 interface=sfp1-WAN1 network=11.11.11.8
add address= 22.22.22.10/30 interface=ether2-WAN2 network=22.22.22.8
add address=192.168.91.2/24 interface=ether5-LAN network=192.168.91.0
add address=172.16.10.30/30 interface=eoip-tunnel1 network=172.16.10.28
add address=172.16.10.34/30 interface=eoip-tunnel2 network=172.16.10.32
add address=172.16.10.42/30 interface=bonding1 network=172.16.10.40
add distance=1 gateway=172.16.10.41
add distance=1 dst-address=5.5.5.5/32 gateway=11.11.11.9
add distance=1 dst-address=5.5.5.3/32 gateway=22.22.22.9
