Hi guys. I’m trying to do load balancing and failover over two ADSL lines. The problem is that both lines are from the same ISP, and both are PPPoE. So the IP is always dynamic (can’t request static IP), and the biggest problem is that both connections always give me the same gateway. This seems to be the biggest problem.
Traffic comes from two separate offices and the idea is that one office (10.1.1.0/24) comes out through ADSL 1, and office 2 (10.2.1.0/24) comes out through ADSL 2. If either ADSL connection fails, route the traffic through the remaining ISP.
Most examples I’ve seen either use the ADSL modems in Route mode (and NAT twice, which I don’t want) or use two separate ISPs, which gives you two different gateways.
I tried adding a static route and using the “Pref Source” address option, but that doesn’t work. All traffic just goes through one of the modems and the other is idle.
How can I make traffic go through one connection or the other based on the source (LAN) address, if the gateway address is the same?
I’m doing Load balancing/fail over over 6 DSL based lines, we use PCC to do this. 2 of our lines are on the same “network” and I had problems with them when i first set them up, but with help i got them working. here’s a link to the PCC page if you need to set it up first. ( http://wiki.mikrotik.com/wiki/Manual:PCC )
the part I had to change was where the gateway was looked for, here’s a clip of my code.
instead of being the pppoe-out interface, I had to set it to the gateway IP (in my case 108.219.188.1) and add %INTERFACENAME to the end, so it would always go out that port even tho the other one had the same gateway. if you want, I can post my entire PCC code and you can edit it to your needs.
this may not do exactly what you want as is, but its a start that will get you going in the right direction.
