I have 4 WANS, Ether 1 to Ether 4 is the WANS.
Two Local Servers are coming from 1 Wan, that Wan port is Ether4.
Ether5 is Lan port.
Local Server IP Addresses is:
First server IP: 202.21.176.98
Second Server IP: 192.168.255.1
I am pinging from Lan.
This is my load Balance Script
/ip firewall mangle
add action=mark-connection chain=prerouting connection-state=new in-interface=bridge new-connection-mark=conn1 nth=4,1
add action=mark-routing chain=prerouting connection-mark=conn1 in-interface=bridge new-routing-mark=conn1 passthrough=no
add action=mark-connection chain=prerouting connection-state=new in-interface=bridge new-connection-mark=conn2 nth=4,2
add action=mark-routing chain=prerouting connection-mark=conn2 in-interface=bridge new-routing-mark=conn2 passthrough=no
add action=mark-connection chain=prerouting connection-state=new in-interface=bridge new-connection-mark=conn3 nth=4,3
add action=mark-routing chain=prerouting connection-mark=conn3 in-interface=bridge new-routing-mark=conn3 passthrough=no
add action=mark-connection chain=prerouting connection-state=new in-interface=bridge new-connection-mark=conn4 nth=4,4
add action=mark-routing chain=prerouting connection-mark=conn4 in-interface=bridge new-routing-mark=conn4 passthrough=no
add action=masquerade chain=srcnat connection-mark=conn1 out-interface=ether1
add action=masquerade chain=srcnat connection-mark=conn2 out-interface=ether2
add action=masquerade chain=srcnat connection-mark=conn3 out-interface=ether3
add action=masquerade chain=srcnat connection-mark=conn4 out-interface=ether4
/system script
add name=ether2_force policy=read,write source=“:if ([/interface find name="e
ther2"] = "") do={\r
\n\t:error "Target interface does not exist";\r
\n\t}\r
\n\t\r
\n:if ([/interface get [find name="ether2"] disabled ]) do={\r
\n\t:error "Target interface ether2 is disabled.";\r
\n\t}\r
\n\r
\n:if ([/ip dhcp-client find interface="ether2"] = "") do={\r
\n\t:error "Target interface is not running a DHCP client.";\r
\n\t}\r
\n\r
\n:if ([/ip dhcp-client get [find interface="ether2"] status] != "bound
") do={\r
\n\t:error "DHCP client is not bound to an address.";\r
\n\t}\r
\n\t\r
\n:local dhcpgateway [/ip dhcp-client get [find interface="ether2"] gate
way];\r
\n:if ($dhcpgateway = "") do={\r
\n\t:error "Interface has not been assigned a gateway address.";\r
\n\t}\r
\n\t\r
\n:local oldgatewayid [/ip route find comment="ether2_force"];\r
\n\r
\n:if ("$oldgatewayid" = "") do={\r
\n\t:log warning "Adding route";\r
\n\t:execute "/ip route add \\r
\n\t\tdst-address=0.0.0.0/0 \\r
\n\t\tcomment=ether2_force \\r
\n\t\trouting-mark=conn2 \\r
\n\t\tgateway=$dhcpgateway";\r
\n\t:error "All done.";\r
\n\t}\r
\n\r
\n:local oldgateway [/ip route get number="$oldgatewayid" gateway];\r
\n:if ("$oldgateway" != "$dhcpgateway") do={\r
\n\t/ip route set numbers="$oldgatewayid" gateway="$dhcpgateway";\r
\n\t}\r
\n\r
\n#The Same IP Gatway\r
\n\r
way];\r
\n\r
\n /ip route set [find comment="ether2_force"] gateway=($dhcpgateway."
%ether2")\r
\n\r
\n# Disable Schedule\r
\n\r
\n:local RCount [/system scheduler get [find name =schedule2] run-count]\r
\n\r
\n:if ($RCount >2) do={\r
\n/system scheduler set [find name="schedule2"] disable=yes\r
\n#: log warning phalla;\r
\n}”
add name=ether3_force policy=read,write source=“:if ([/interface find name="e
ther3"] = "") do={\r
\n\t}\r
\n\t\r
\n:if ([/interface get [find name="ether3"] disabled ]) do={\r
\n\t:error "Target interface ether3 is disabled.";\r
\n\t}\r
\n\r
\n:if ([/ip dhcp-client find interface="ether3"] = "") do={\r
\n\t}\r
\n\r
\n:if ([/ip dhcp-client get [find interface="ether3"] status] != "bound
") do={\r
\n\t}\r
\n\t\r
\n:local dhcpgateway [/ip dhcp-client get [find interface="ether3"] gate
way];\r
\n\t}\r
\n\t\r
\n:local oldgatewayid [/ip route find comment="ether3_force"];\r
\n\r
\n\t\tcomment=ether3_force \\r
\n\t\trouting-mark=conn3 \\r
\n\t}\r
\n\r
\n\t}\r
\n\r
\n\r
\n\r
way];\r
\n\r
\n /ip route set [find comment="ether3_force"] gateway=($dhcpgateway."
%ether3")\r
\n\r
\n\r
\n:local RCount [/system scheduler get [find name =schedule3] run-count]\r
\n\r
\n/system scheduler set [find name="schedule3"] disable=yes\r
\n}”
add name=ether4_force policy=read,write source=“:if ([/interface find name="e
ther4"] = "") do={\r
\n\t}\r
\n\t\r
\n:if ([/interface get [find name="ether4"] disabled ]) do={\r
\n\t:error "Target interface ether4 is disabled.";\r
\n\t}\r
\n\r
\n:if ([/ip dhcp-client find interface="ether4"] = "") do={\r
\n\t}\r
\n\r
\n:if ([/ip dhcp-client get [find interface="ether4"] status] != "bound
") do={\r
\n\t}\r
\n\t\r
\n:local dhcpgateway [/ip dhcp-client get [find interface="ether4"] gate
way];\r
\n\t}\r
\n\t\r
\n:local oldgatewayid [/ip route find comment="ether4_force"];\r
\n\r
\n\t\tcomment=ether4_force \\r
\n\t\trouting-mark=conn4 \\r
\n\t}\r
\n\r
\n\t}\r
\n\r
\n\r
\n\r
\n\r
way];\r
\n\r
\n /ip route set [find comment="ether4_force"] gateway=($dhcpgateway."
%ether4")\r
\n\r
\n\r
\n\r
\n:local RCount [/system scheduler get [find name =schedule4] run-count]\r
\n\r
\n/system scheduler set [find name="schedule4"] disable=yes\r
\n}”
add name=ether1_force policy=read,write source=“:if ([/interface find name="e
ther1"] = "") do={\r
\n\t}\r
\n\t\r
\n:if ([/interface get [find name="ether1"] disabled ]) do={\r
\n\t:error "Target interface ether1 is disabled.";\r
\n\t}\r
\n\r
\n:if ([/ip dhcp-client find interface="ether1"] = "") do={\r
\n\t}\r
\n\r
\n:if ([/ip dhcp-client get [find interface="ether1"] status] != "bound
") do={\r
\n\t}\r
\n\t\r
\n:local dhcpgateway [/ip dhcp-client get [find interface="ether1"] gate
way];\r
\n\t}\r
\n\t\r
\n:local oldgatewayid [/ip route find comment="ether1_force"];\r
\n\r
\n\t\tcomment=ether1_force \\r
\n\t\trouting-mark=conn1 \\r
\n\t}\r
\n\r
\n\t}\r
\n\r
\n\r
way];\r
\n\r
\n /ip route set [find comment="ether1_force"] gateway=($dhcpgateway."
%ether1")\r
\n\r
\n\r
\n:local RCount [/system scheduler get [find name =schedule1] run-count]\r
\n\r
\n/system scheduler set [find name="schedule1"] disable=yes\r
\n}”
/system scheduler
add disabled=yes interval=10s name=schedule1 on-event=
“\r
\n/system script run ether1_force” policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-time=
startup
add disabled=yes interval=10s name=schedule2 on-event=
“\r
\n/system script run ether2_force\r
\n” policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive
start-time=startup
add disabled=yes interval=10s name=schedule4 on-event=
“\r
\n/system script run ether4_force\r
start-time=startup
add disabled=yes interval=10s name=schedule3 on-event=
“\r
\n/system script run ether3_force\r
start-time=startup
add name=Enable-All-Schedules on-event=" /system scheduler set [find name="sc
hedule1"] disable=no;\r
\n\r
\n /system scheduler set [find name="schedule2"] disable=no;\r
\n\r
\n /system scheduler set [find name="schedule3"] disable=no;\r
\n\r
\n /system scheduler set [find name="schedule4"] disable=no;\r
\n\r
\n /system scheduler set [find name="schedule5"] disable=no;" policy=
startup
