Load Balancing and network sharing in different range
WAN 1 ip range : 192.168.0.1/24
WAN 2 ip range : 192.168.1.1/24
Ethernet 3 ip range : 192.168.10.1/24
Server IP : 192.168.0.200 this is is DMZ from 91.187.x.x
i have load balancing in mikrotik
but i have problem with network sharing i need to connect from ethernet 3 range 192.168.0.0/24 to server 192.168.0.200
where is problem pls help ..
Make a routing rule that forces the lookup table to be the main table when the destination IP address is 192.168.0.0/24
this is in the ip > route > rules menu.
